Need help removing adware without going into safemode.
11 Oct 2008
London
Hey guys,
So i managed to get some adware and i cant access CMD to remove it. I also cannot get into safe mode because i am currently using a laptop which has got a cracked screen and im using it via a vga cable connected to my monitor. I have tried booting safe mode but nothing is coming up on my monitor and decided to come on the cracked screen instead.
Any tips?
THanks
Can you remove the hard drive and put it in another machine/USB caddy?
This is my preferred way of dealing with virii anyway.
I've successfully cleaned a machine without going into Safe Mode using Malwarebytes' Anti-Malware. Just install, update & then run Full Scan
As above, use the function keys on the keyboard to switch to the external screen.
