Hi guys,
Right i've been looking around and it seems a lot of routers seem to be having problems here and there, and i had initially thought that netgear was a sure bet for some decent hardware, but seems others disagree.
So what i'm looking for is a suggestion for a good replacement for the BT HomeHub 2.0, i personally don't have many problems with it connected through ethernet. However the lady of the house is .... biting my head off, for lack of better words... that her wireless connection is failing. And that it is, i've yet to have a quiet week since installing the hub, her laptop connects, the laptop sees the hub, the hub sees her laptop.
Problem is the connection is insanely slow, to almost non-moving, even though her signal strength is full. I've put it down to the hub being rather shoddy, so wonder if anyone can suggest a better router which works with bt's broadband, to replace their hub.
Note: it will be on 24/7, so something reliable which isn't going to overheat would be nice (i see this can be a common problem.)
Edit: I say router, assuming it is indeed a router i require and not a modem, almost certain it's a router, feel free to correct me however ^^
Thanks
-fedexer-
Thanks
-fedexer-
