Back in March 2010 I got one of the i3 530 @ 4Ghz bundles and all in all it's been awesome, really quick and stable.
Unfortunately a couple of days ago I lost the BIOS settings and am now struggling to return it back to the same speeds whilst staying prime95 stable. I'm not overly familiar with overclocking these days so not sure what it is I need to be changing to get the last 150Mhz out of the cpu.
To the best of my knowledge it was: -
Vcore = 1.325V
QPI/Vtt = 1.31V
VDRAM = 1.66V
BCLK = 182Mhz
Memory = 1456Mhz
Ratio = 22
I think everything else was set to auto or normal.
When I got the bundle the cpu was getting hotter than expected and typically ran about 70-75°C on load, I reduced the VCORE to around 1.25V and it stayed stable at that whilst reducing load temps to the mid 60s.
I have managed to get it to run an hour or so or prime95 blend torture test at 182 BCLK with 1.2625V but when running it again this morning it failed on anything more than 170 BCLK.
Is there any chance that someone might have the exact settings for the i3 530 bundle so I can set them again.
My PSU is now pretty old so perhaps it's possible that it's not giving stable enough power any more, is there any way to test this out? It's an OCZ modxstream 520 which is a good 7-8 years old now so quite possibly due for replacement but I want to get the BIOS settings right before I spend money that I'm meant to be saving for a wedding in June
Any advice would be very much appreciated!
edit: it seems to run the large FFT torture test quite happily, yet will fall over on the blend test within a minute or two. I ran memtest86 and it said no errors, is there anything else I could do to check the ram further?
Vcore = 1.325V
QPI/Vtt = 1.31V
VDRAM = 1.66V
BCLK = 182Mhz
Memory = 1456Mhz
Ratio = 22
