Need help ripping a track to MP3 from CD!
17 Dec 2006
I have the 2 Many DJ's As Heard on Radio Soulwax Part 2 CD and for the life of me I cannot find any program that will rip the hidden track to the hard drive. The track itself is BEFORE the first track. Ie. to listen to it you'd put the CD in the player, then as soon as it's about to play hold rewind and you'll end up about -4:45 and you get a hidden Kylie Minogue - Can't Get You Out Of My Head remix. No programs however seem to allow you to rewind before 0:00.
Thought this might be better in the music part than the Windows sub-forum, so decided to post here. If not then if a moderator could possibly move this over that would be great!
The remix is excellent as well and if someone can possible tell me how to get it from the bloody CD to the hard drive I'd be appreciative :)
you would have to record it real time through a sound recording program like adobe audition or audacity, just set your windows mixer to record via the 'what you hear' or 'wav' channel and record whilst your listening. then encode it to mp3
Cheers I'll give that a try, although will that not kinda destroy the quality of the track? Was hoping to have it at high quality like the others and not muffled.
it wont be muffled it will record it as close as you are hearing it, ok the noise floor will be higher, but not noticeable on the ear only in a frequency analysis, when your encoding it encode it higher than what it is already so if 128 make it 192.
That's how a lot of CD rippers used to work anyway. Quality is pretty good as long as you get the input levels right.
