need help setting up 2 monitors
5 Sep 2011
Nottingham, UK
i just got a digimate 23 inch monitor with dvi (not working) and vga which i am connected too... and want to set up my old 19 inch widescreen along side it for dual display...
i am using a asus gtx560 which dual dvi ports on it and whenever i hook both monitors up and mess around with the settings... my main monitor (23") is fine but the old 19" monitor is blurry and distorted and nvidia control panel will not find the monitors native resolution of 1440*900 and i have to create a custom resolution but it is still blurry etc and really doing my nut in...
i have swapped around dvi converters and vga cables etc but nothing seems to work... any ideas please?
