Hi, right I'm completely stuck with creating firewall rules.
Basically, I have a Draytek Vigor 2600 and I have created a firewall rule that blocks all outbound traffic TCP/UDP from a certain IP ... this works fine, as when that rule is active, the PC designated is no longer able to access the internet, ping anything.
Now what I am stuck on is allowing port 80 so as to allow internet access only. I have setup a rule that states Pass immediately any outbound traffic on port 80 from the certain IP, I have also redirected the port forwarding as per the NAT setup.
I've posted on the manufacturers forum, but no reples so far. I just can't seem to be able to get it to work.
Any help is much appreciated.
Cheers
Cheers
