need help specing a PC
8 Apr 2009
Tavistock,Devon,England
hi guys
need help specing a new oc build i want a Intel Core 2 Quad Q9650 LGA775 'Yorkfield' 3.0GHz GTX graphic card/s (not ATI) DDR3 and i would like to be able to SLI the GPU or the same spec but witb a AMD Phenom II X4 Quad Core 955 Black Edition
regs
Why have you got 2 threads the same? youre just going to confuse matters
Heres a good AM3 build, uses ATI though as AMD dont support SLI on new AM3 yet, afaik
If you insist on NVidia then youre best going i7 (socket 775 is dead), tho it creeps slightly over your budget
