Caporegime
- 21 Jun 2006
right ok my little 9 yr old brother has just spilt some strawberry flavoured volvic all over my ntl cable modem, now that it has dried the modem will only work when directly connected to by one pc, the router no longer works, but the router was on a different shelf than the modem and had no water spilt on it, is it possible that it was short circuited by the ethernet lead it had going into the modem? i have restarted everything and tried several times with no luck, i can only connect to the internet through the modem, i can however connect to the router and talk to its built in firmware, so is the lead going from the router to the modem knackered?
