what is the fsb and what does it do
what is the northbridge and what does it do
what is the southbridge and what does it do
what are mosfets aside from metal oxide semiconductor field effect transistors
what does the 45nm and 65nm actually mean ??
Use this website to search for what you want, it will be easier for you The link basically answers your first 3 questions (look at the picture for the second two questions).
