Need help upgrading laptop RAM
14 Jun 2010
I can't find any information if this Samsung NP530U3B Series 5 laptop supports 1.35 volts RAM, it currently has 4GB soldered and 2GB socketed both runing at 1.5V. Curical website says it supports 1.35v ? but would two different RAM sticks ruing at different voltages work?
Edit: sorted now
Pull the socketed stick
check the sticker
Buy higher capacity ram same as the specs on the stick you pulled :)
Its the voltage im not worried about Im not sure why some memory websites say the 1.35V is compatible but the one i pulled out is 1.5v and the soldered is 1.5v
in my experience pretty much all of it will just work at 1.35 up to 1.5v - I wouldn't even be worrying just shove a 1.35 in there and be done with it.
