I got me a set of logitech z 5500's a few weeks ago.
The sound from the rear speakers is weird compared with the front speakers. They only seem to play some of the sounds and don't seem as loud as the front speakers. Are they supposed to be like this?
the rear speakers work the same as the front when i switch the effect to stero x2 but then the center speaker doesn't work.
I googled the problem and it came back with the with lack of support from programs using 5.1 and downloading SRS audio sound box would help (which it hasn't)
So any one got any ideas . I'm using the optical input for the sound (through my mobo) I also have a sound card that i have my 5.1 headset pluged into. I'm on xp 64 bit if that helps.
So any ideas or advice?
