Need help with a capo...
23 Sep 2003
Can anyone recommend me a guitar capo? The one i've got at the moment is made from plastic....it's not too bad but I want one that is of better quality. The plastic one is pretty difficult to put on properly without using a bit of force.
Excellent. That's the sort of thing im after. Going to go into town tomorrow and see if i can pick one up there. If not i'll order it online. Thanks.
I have two Kyser capos and have found them to be superb. I would recommend a G7th Performance capo though. The main reason being that the Kysers start to lose their ability to spring back after a while. That being said, I'd always use Kyser myself. So it's really up to you.
But both of those would be my preference.
I've used a Shubb Capo Deluxe for years, pretty good it's been too. The rubber sleeve has started to split on mine after approx 10 years of use but they're replaceable anyway.
