Need Help With A Card Reader
Have you got another header on the motherboard you can try? If it doesn't can the reader be connected via a usb port rather than header (some can) - i know this wouldn't be ideal but if it worked through a usb port you would know that your usb header or the usb header cable was broken. And, obviously, vice versa if it didn't work - i.e. the card reader's borked.
Additional: have you tried forcing windows to try and identify it through add hardware?
