Permabanned
- 19 Jul 2012
- Buckinghamshire
I have a CiT Vantage case with Blue LEDs.
http://t0.gstatic.com/images?q=tbn:ANd9GcSb9j1PSvw72sRf_r5emUuQWHZJQZivjU0YJO2CvWhZErypOSsm
No hotlinked images. Thank you.
Sorry
The front fan connector is messed up. I wanted to replace the front and back fans for better air flow.
Wanted to know if this fan will work good?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-013-CM&groupid=701&catid=2331&subcat=4
Also do these led case fans come with the molex plug already attached? I ask because I don't want to do wiring. I just want to install and it works.
Thanks
Sorry
Thanks
I understand case fans are expensive, I got into bad habit of spending too much on my computer. Good luck.
