Need help with a little batch script
26 May 2006
Edinburgh
I am trying to write a simple batch script to do the following:
If the location of an exe file doesn't exist then run an exe from another location. And to keep things neat, add add an else command if the location of the exe already exists.
I have tried this so far:
IF NOT EXIST c:\testlocation\test1.exe \\networklocation\testnew.exe ELSE echo File already exists
Doesn't appear to be working and I cannot see much wrong with the code.
Any help would be great.
Try:
Code:
IF NOT EXIST c:\testlocation\test1.exe ( \\networklocation\testnew.exe ) ELSE (echo File already exists)
Also, have you confirmed that you can run the exe from the network path in a command window?
