hey guys,
rite firsts first... i need help and advice with a lot! i mean a lot!
so xmas is coming up and i have a lot to buy (sister in law pc upgrade/prezzies for family etc..) and also for myself
now im still looking at the HAF x/gtx480SLI/watercooling
and i need some peoples advice on my overclock (i have a feeling its wrong somewhere and i dont want to system to fail on me!)
heres my system spec atm :
i5 760 @4ghz
msi p55 GD80
corsair xms3 2x4gb 1600mhz
antec kuhler 620 cooler
asus gtx480 (refrence design)
antec true power 750w
seagate barrcuda 1TB 32mb cache
coolermaster cm690 ii lite
so heres my settings from cpu-z
CPU:
core voltage 1.25V
core speed 4000.MHz
multiplier x 21.0
bus speed 190.5 MHz
QPI link 3048.5 MHz
Memory:
NB frequency 3048 MHz
DRAM frequency 762 MHz
9-9-9-24
dose that seem rite for a overclock ??
with less than 10mins on intel burn test it got up to 80 degrees, i should lower my overclock ??
also my gtx480 at standard speeds reaches 80 degrees in games
now about the HAF X.. as im getting really high temps with my system, should i invest in this case as its got great air cooling and as i have a Fermi card ??
another question for the HAF X users, if you remove the HDD cage, could a 240 rad fit in there ??
now about GTX480SLI.. im not able to fully max out bf3 (properly not skyrim either) or even begin to overclock my 480 as it reaches 80 degrees on standard speeds! so im thinking of picking up a second 480 for SLI if i can get them cool. also how much improvement do you get with a second 480 ?? is it worth the money ??
now about watercooling.. as i have a fermi card that gets extremely HOT! as well as my cpu reaching high temps, should i invest in watercooling these with a custom loop ? or even if i went form my cooler to a EK kit first then build the loop larger as i go ?? if i do get 480SLI and watercool them with my cpu, will i get 1GHz out of each card or am i dreaming again ??
any help or advice appreciated!
sorry for such a large list but i cant seem to get my head round it and my best bet is to ask you guys!
cheers fellas
i5 760 @4ghz
msi p55 GD80
CPU:
core voltage 1.25V
core speed 4000.MHz
multiplier x 21.0
bus speed 190.5 MHz
QPI link 3048.5 MHz
Memory:
9-9-9-24
cheers fellas
