Need Help with a PC build roughly around £400-500
18 Aug 2017
My Friend recently has recently gotten into PC Gaming and has asked me to help her build a new system roughly around the £400 to £500 price margin, all it needs to do is run League of Legends, World of Warcraft and possibly some low spec games. Any thoughts?
Thanks a lot.
Is it just the base unit she needs for £500 - or are you after the whole kit-and-kaboodle - i..e. monitor, keyboard, windows?
She could probably get away with the base unit to be honest, then afterwards we can look at possibly upgrading her peripherals somewhere down the line.
Thanks a lot for that, i'll have a look into it and have a chat with her about it all :)
CPU
AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor
£95.99
Motherboard
Asus - PRIME A320M-K Micro ATX AM4 Motherboard
£56.69
Memory https://cdn.************.com/static/forever/images/product/5c8997ffc1fb1d8763283766c6d07ac7.256p.jpg
Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory
£74.68
https://uk.************.com/mr/morecomputers/BYH48d
Storage https://cdn.************.com/static/forever/images/product/0ac8405623f759a935d6b83298c02f10.256p.jpg
Western Digital - Blue 250GB 2.5" Solid State Drive
£79.68
Video Card https://cdn.************.com/static/forever/images/product/b5085de8608652aaa8887a68642fcd36.256p.jpg
Palit - GeForce GTX 1050 Ti 4GB StormX Video Card £128.99
Case https://cdn.************.com/static/forever/images/product/f2826edd322942d3535117a360fe78ff.256p.jpg
Deepcool - TESSERACT SW RED ATX Mid Tower Case
£34.00 £34.00 [URL='https://uk.************.com/products/power-supply/']Power Supply https://cdn.************.com/static/forever/images/product/6ef8c3b4a071123523d11638584c2596.256p.jpg
Corsair - Builder 500W 80+ Bronze Certified ATX Power Supply[/URL]
Operating System https://cdn.************.com/static/forever/images/product/c9b365727400c92a7ffcb533826dd224.256p.jpg
Microsoft - Windows 10 Home OEM 64-bit
£82.20
My basket at Overclockers UK:
Total: £496.62
(includes shipping: £11.70)
Haven't played wow since 2012 just as the panda expansion was realised, but up till then I used to play it all on not even half the performance of this computer and it was a laptop faultlessly on high settings, so you would have no problem running it or the other games.​
Dont forget, if she has a monitor with a vga lead ( basically a flat screen monitor thats about 7 years old) , u will need an adapter to fit the gfx card,
VGA (female) to DVI (DVI-I/DVI-A) Monitor (male) Display Adapter
£3 from your favourite internet auction site :)
I really would spend an extra £5 - £15 on a B350 motherboard. Even a mild overclock can net some decent gains in performance on that R3 1200 and the cooler that comes in the box is fine for a mild OC.
i agree ...
Biggest selling point for ryzen 3 is ability to overclock ... why not use it?
Tidy spec Exo - the Aerocool is a nice budget case but no optical bay :)
Ha cheers, it's quite handy of AMD to create those R3 1200 processors, ideal for these budget builds and I'm sure that quad is better than the older generations of 4c4t aswell.
Ha I didn't take notice the case didn't have a drive bay, I saw how nice and sleek it looked, but then I only added an optical because the other person did, op might not even need one.
