need help with AMD X2 4800....
Permabanned
26 Feb 2006
hey i just got the AMD X2 4800, and i also purchased some cooling compound but on the heat sink there is a grey square of something or other do i need to use this compound or does that stuff already on the heat sink do the job???
thanks,
Jack
the stuff i purchased today is called, "Titan Nano Blue". can't i just use the stuff that's already on there?
i don't plan to overclock it...
If it's the stock AMD cooler which came with the CPU then it'll be fine.
I actually had to swap out a zalman aero flower for the stock cooler (X2 4400) and it's actually quieter (although I didn't use the fan controller on the zalman).
Edit: scrub that... I had to use thermal paste as the stock controller didn't have any... poor memory this brain and that's me on coffee! :D
If the cooler is AMD X2 compatible (within specs) then you'll still probably be fine. Keep the paste for next time. :)
