Need help with an excel formula
18 Oct 2002
Im trying to enter a formula that calculates a starting value in currency in one cell, and calculates the difference between a second cell with a finishing value . I.e [a1]£100 [b1]150 [c1]+50
[b2]150 [b2]120 [c2]-30
the reason im struggling is its not a simple + or -, and i dont know the statements that controls if its a plus or a minus. For example i tried, and this and i didnt work
=if(a1<b1),then(a1-b1),else(a1+b1)
:p i dont even think excel recognises else, :D
Anyone know a simpler way of calculating the profit or loss from two money values. I'e googled loads with no luck. Thanks.
I don't really understand what you're trying to do I'm afraid, but if you're trying to find the form of a conditional 'if', then try this:
=IF(A1<B1,A1-B1,A1+B1)
If you are trying to get to the absolute value of the difference between two numbers (i.e. without any minus signs) then you could use =ABS(A1-B1).
HTH
ok sorry, basically
I need a sum to calculate +/-
however the problem im having is its not a simple plus or minus equation because if the closing balance is higher than the starting balance it needs to be a + if its lower then its needs to be a minus.
make sense?
So you just want to show a "+" or "-" and possibly an "=" in column D based on starting and closing balance?
If so try this in D2 =IF(C2>B2,"+",IF(C2<B2,"-","="))
It's easier to do =c2-b2 and then change the number format on the cell to Custom so it displays the + or - symbol
Spot the deliberate mistake; should read +£#,##0.00;-£#,##0.00 in Type - got the pound symbol in the wrong place on the screeny
