So this morning i started fiddling with ASP.net 2.0 since i was board and think i need it for collage.. anyway
all went well then for no apparent reason the login boxes and password recovery etc bits dont work.
They work fine if i boot up VWD and debug the application but if i close it, and try and get to the site normally it dosent work.
Thing is as far as i can remember it was working so i've probably 'ed something up (although i cant remember fiddling with anything!)
Firstly the server is IIS 5.1 or whatever the one that comes with XP pro is
My connection string in the ASP.net settings is :
data source=.\SQLEXPRESS;Integrated Security=SSPI;AttachDBFilename=|DataDirectory|aspnetdb.mdf;User Instance=true
looks right to me?
and the actual error is
Failed to update database "C:\INETPUB\WWWROOT\APP_DATA\ASPNETDB.MDF" because the database is read-only.
apparently. the physical file system is fine, its not checked as read-only. and just for safe measure i tried allowing the site to read and write and all that in the properties in IIS.
so any ideas?
tia
alec
looks right to me?
so any ideas?
tia
alec
