Need help with basic gaming pc
10 Apr 2018
Hi people. Want to buy a pc gaming setup. Dont mind building myself but on a tight buget as other half has been off work ill for some months now. Just want pc that will play basic stuff like. Gold rush- my summer car.- truck simulator and also be able to play more graphic games like cod ww2. Ive seen that for about £350 this could be possible. Any help what whats best would be great.
Need peripherals?
1080p
In my opinion you aren’t building something suitable for that budget unless you’re buying second hand.
Wait til Nvidia launch their new range and nab a 1060 second hand, and build the rest from there. I’d still consider a higher budget though dude, sorry.
Edit : I built the cheapest of the cheap rig with a bottom end ryzen, 1050 and no ssd, it came to £430, not a great spec at all but it shows you the bottom line first hand.
Whatever you do don’t buy a bottom rung psu, I specced the 500w evga.
