So, I decided to look through my Motherboard settings to make sure my PC is performing the best it possibly can. I've fixed obvious things such as fan speeds which I want on maximum.
There is a few settings here which I dont know if I should disable or enable. I'd appreciate anybodys pro advice in what I should do with these settings. My current setup = GTX 580, I7 960 @ 3.2GHz, 6GB 1666 RAM.
Here are my questions:
1. Extreme Memory Profile (Disabled) If I enable this it will allow my RAM to run at 1666MHz, Should I enable this? Will I notice ANY difference at ALL from enabling this feature?
2. Performance enhance (Turbo) What would happen if I was to change this feature to (Extreme) ??
3. eXtreme Hard-Drive (Disabled) What would happen if I was to enable this feature?
4. Sata Port 0-3 Native Mode (Disabled) What would happen if I was to enable this feature?
5. Azalia Codec (Auto) What the hell is this? Can I disable this? Please let me know what the hell it is.
6. HPET Mode (32 Bit) What would happen if I was to change this to 64 Bit mode?
7. I know some guy with a GTX 570, and plays at a HIGHER resolution than me. so technically he should get lower framerates than me as my GPU is better and I play at a lower resolution but on DayZ he seems to get over 20 FPS higher than me. The only difference is that he has an I5 2500K @ 4.5GHz. Will his CPU at 4.5 GHz REALLY increase his FPS by that much over mine?
I'd appreciate someone very knowledged in this area to answer my questions above.
Thank you very much
Thank you very much
