Need help with build - budget ~3k
2 Sep 2022
UK
Hi guys,
PC components are finally available and for a decent price.
I want to build gaming PC which will last for few years. Mainly to play FPS and online gaming.
My budget is 3k for a PC. I also need to buy a monitor within this budget.
Can you please help me to build a PC and select monitor?
Thank you
You may want to wait for the AM5 independent reviews to be out so you can see how those chips perform.
Monitor. This is the choice you should make first. There is no perfect monitor for everyone and there is a huge choice so you need to decide on 4k , ultrawide , high refresh rate etc etc etc and then see what the best choice is for your particular needs. Once you have a monitor in mind you can decide on the actual PC.
