Need help with cable for 2 side fans.
Permabanned
19 Jul 2012
Buckinghamshire
I'm using 2 of these as my side fans.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-008-AE&groupid=701&catid=2331&subcat=4
I just bought this fan controller
http://www.overclockers.co.uk/showproduct.php?prodid=BB-006-AE&groupid=701&catid=2331&subcat=189
And my mobo only has 3, 3pin connectors. I wanted to use the 2 side fans with 1 connector into my fan controller.
1) Can I control 2 fans at once with 1, 3pin on my fan controller?
2) which 3pin splitter cable will I need?
The fans are 12v 3pin. It also comes with a Voltage Reduction Cable that is 7v.
Can someone point me to the right cable. I guess I would need 2, 3pin male to a female 3pin?
I couldn't find any?
Edit
Or maybe these might work?
http://www.overclockers.co.uk/showproduct.php?prodid=CM-094-BX&groupid=701&catid=1428&subcat=2244
Thanks
