Need help with case : Kolink Observatory RGB Mid Tower
12 Jun 2018
I got myself pc case:
everything seems to be ok, but there is no light in 4x led fans...
they are working but there is no light, I connected all 4 of them to the box and then to motherboard but maybe I did something wrong... did anybody bought same case? any chance to get any kind of instructions how to do it properly?
as I can't find anything on internet at the moment... Thank You in advance.
kolink-observatory-atx-mid-tower-rgb-led-tempered-glass-gaming-pc-case.html
The controller is molex powered, not by motherboard, that might be your issue. Furthermore, the fans should be installed in order (top front = 1, middle front = 2) etc.
Thanks a lot for help, so if its molex powered - should I buy some kind of molex coverter cable and connect it stright to my power supply? or how I should connect it please? :/ Im not very good in these kind of things...
All power supplies should have at least 2-3 molex connectors, just plug one straight in to the fan controller :)
Hey man I've got a simillar issue need a new fan controller since the one I had broke down and died out in a puff of smoke. Had to throw that away and now I need a new one So could you guys maybe send me one with remote or show alternatives I can buy ?
Thanks
