when polystyrene dissolves in acetone, what properties does the solution have?
What sort of polystyrene?
The foamy type stuff is full of air, so any gas coming off is probably just air.
What properties of the solution are you looking for here?
For the record, there's loads of information if you google it.
Isn't that the basic ingredients of Napalm?
I have absolutely no idea I'm an useless at chemistry which is why I'm asking about it here
Edit: i asume you are talking about acetone
DEHA (di-2-ethylhexyl adipate)
I'm guessing the polystyrene polymers are being broken down into their monomers, which would be styrene, which is why the cup dissolves. The gas released would be what ever gas was pumped into it in the first place when the polystyrene was initially formed (from styrene), which at a guess I would say was either air or nitrogen (as cheap and harmless).
not the monomers - its just the polymer dissolving in acetone.
no gas is evolved when PS dissolves in acetone - if any gas comes off when dissolving expanded PS it has nothing to do with the PS itself and depends what gas they used to expand the polymer as it was made.
as for the properties of the solution i don't know what they want to hear - its PS in acetone, so it will have the properties of both?!?! a bit of a stupid question to ask.
The only thing I could think of about the solution is that the viscosity would increase quite a lot, though this does depend on amounts and concentrations used, as well as the molecular weight of the polystyrene.
true, i forgot about that - but you need quite a lot of polystyrene to make it viscous.
Just checked with my Chemistry housemate. Napalm is sugar, polystyrene and petrol.
ah that will teach me for guessing on a forum![]()
Benzene for military grade
OOoooooh, that old chestnut!!! Was on the tip of my tongue you know!!
Or perhaps not, I failed A2 Chemistry![]()
