- 26 Sep 2017
- In the Masonic Temple
Hi there,
I have a vega and will be buying the ek full water block for it, with a pump/res combo and a aplhacool 240mm radiator.
I really need help as the tubing is confusing and also which is better of these 2 pump/res combos?
https://www.overclockers.co.uk/xspc-ion-all-in-one-pump-reservoir-white-wc-404-xs.html
or
https://www.overclockers.co.uk/ek-water-blocks-ek-xres-100-ddc-mx-3.1-pwm-incl.-pump-wc-9fk-ek.html
As for the tubing, would someone be so kind as to tell me what to buy, i want soft tubing, clear with aim of having mayhem silver running through it, so i will need 6 fittings for the g1/4 holes in the rad block and pump. 2 of these need to be 90 degree ones for the gpu block and compression fittings to go with them.
If someone could show me the way I would be sincerly grateful.
Thank you
My basket at Overclockers UK:
or
Thank you
- 1 x EK Water Blocks EK-FC Radeon Vega RGB - Nickel= £109.99
- 1 x Mayhems Aurora 2 Silver 1ltr= £9.95
- 1 x XSPC Ion All In One Pump Reservoir (White)= £56.99
Total: £187.43 (includes shipping: £10.50)
