Need Help with Deciding on a Motherboard
21 Nov 2011
Glasgow, Scotland
Hey Everyone,
I will be upgrading my PC soon and I need help to choose a motherboard, My specifications will be :
i5 2500k (I will overclock myself)
Nvidia GTX 570 ASUS Direct CU II
Kingston HyperX Genesis 8gb 1600MHz RAM
Corsair CX600 V2 PSU
Cooler Master HAF 922
Hyper 212 Evo CPU Cooler
1tb Hard Drive, Dont care about the DVD-RW Tbh.
So I want to decide on what motherboard I should get between the ASUS P8Z68-V Pro and the ASRock Extreme3 Gen3. Both get their fair share of great reviews. I will be overclocking my i5 to around 4.5-4.6 GHz. The ASRock Extreme3 Gen3 is my preferred board due to costs, And does not seem much different from the ASRock Mobo. Please let me know what you think, Cheers
Kriss
not brought any of that yet? can you reuse current sata hard disk/s? the current prices are too high, 1tb are £100+ where before they were £40 or so.
do you plan on sli? if so then you'll want a better psu and the asus 570 is a triple slot cooler card so not suitable for sli as it'll restrict air flow also the cooler dumps hot air in the case whiich will increase the temps.
whats the budget?
if no plan on sli then I would suggest the gigabyte z68ap-d3 motherboard.
if buying between today and next tuesday night then I would suggest something like
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £239.99
(£199.99) £239.99
(£199.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £161.99
(£134.99) £161.99
(£134.99)
Cooler Master HAF 922 Case - Black Cooler Master HAF 922 Case - Black £86.99
(£72.49) £86.99
(£72.49)
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £79.98
(£66.65) £79.98
(£66.65)
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £59.99
(£49.99) £59.99
(£49.99)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £39.95
(£33.29) £39.95
(£33.29)
Cooler Master Hyper 212 Evo CPU Cooler (Socket Intel® Socket LGA1366/1156/1155/775/AMD Socket FM1/AM3+/AM3/AM2+/AM2) Cooler Master Hyper 212 Evo CPU Cooler (Socket Intel® Socket LGA1366/1156/1155/775/AMD Socket FM1/AM3+/AM3/AM2+/AM2) £26.99
(£22.49) £26.99
(£22.49)
Sub Total : £579.89
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £14.75
VAT is being charged at 20.00% VAT : £118.93
Total : £713.57
use the voucher code CMDOUBLE to get £20 off so £693 total as they're currently doing the offer where if you buy any cm case + either the 500w or 600w silent pro psu you get £20 off using the code.
whats the budget?
(£199.99) £239.99
(£199.99)
(£134.99) £161.99
(£134.99)
(£72.49) £86.99
(£72.49)
(£66.65) £79.98
(£66.65)
(£49.99) £59.99
(£49.99)
(£33.29) £39.95
(£33.29)
(£22.49) £26.99
(£22.49)
Sub Total : £579.89
DPD Next Day Parcel
Total : £713.57
Ok for the Motherboard its either going to be the ASUS P8Z68-V Pro or the ASRock Extreme3 Gen3 motherboard, Which should I go for?
