My laptop broke down so I need a computer super quick. :/ I heard the GTX 460 had some quality control issues so there are some faulty parts out there. Should I be worried? I really need this system ASAP for university work. I can't afford downtime at this point :/
Also please recommend a better mainboard if I want to go SLI with dual GTX 460s later. If a cheap SLI mainboard can't be bought I may just have to upgrade my mainboard when i am upgrading to SLI.
Thanks!!!
Parts List:
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card
£110.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-238-AS
Intel Core i3 540 3.06GHz (Clarkdale) (Socket LGA1156)
£82.24
http://www.overclockers.co.uk/showproduct.php?prodid=CP-312-IN
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply
£63.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OC
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard
£61.69
http://www.overclockers.co.uk/showproduct.php?prodid=MB-233-GI
Please suggest a different board if I can get SLI support cheap
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit
£56.39
http://www.overclockers.co.uk/showproduct.php?prodid=MY-041-PA
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM
£51.99
http://www.overclockers.co.uk/showproduct.php?prodid=HD-342-WD
Coolermaster RC-600 Gladiator Case - Black [RC-600]
£50.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-178-CM
Logitech UltraX Premium Keyboard - OEM (920-000189) [920-000189]
£12.98
http://www.overclockers.co.uk/showproduct.php?prodid=KB-106-LG
LiteOn IHAS124 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA
£11.74
http://www.overclockers.co.uk/showproduct.php?prodid=CD-097-LO
Total with shipping: £517.68
BenQ G2220HD 22" TFT Monitor 1920x1080 300cd/m2 40000:1 (dynamic) 5ms 16:9 VGA/DVI Glossy Black
£97.99
http://www.******.com/product/158568
I think this is the ideal monitor. There are some that are about £15 cheaper but at 1440x900 resolution and smaller screen.
GRAND TOTAL: £615.67 with delivery (£603.17 without )
Thanks!!!
Parts List:
£110.99
£82.24
£63.99
£61.69
£56.39
£51.99
£50.98
£12.98
£11.74
£97.99
