Need help with finding a cheap delivery co.
Status
Not open for further replies.
3 Jan 2009
Bedfordshire
So far i have tried
parcel2go.com
DHL
Parcelforce
Royal Mail
Interparcel.com
And a few local ones.
Anybody got any sites, as google just keeps giving me the same ones :mad:
Thanks
I am big fan of DPD.
When I had to RMA a motherboard I rang them up and as I went out the door 15mins later they showed up. Deliveries always on time and always pick up promptly.
Although they aren't the cheapest, but I only use them.
parecl2go has always been the cheapest for me. Good CS aswell. Claims were processed in one working day!
What are you trying to send? You can't get much cheaper than £10 for a next day courier!
You can try parcelmonkey
EDIT:http://www.parcelmonkey.co.uk/
Cheers mate your a life saver,
Been getting quotes of £55 - £75
Cheapest was £25 on parcel2go
Problem was we allowed £8,99 for postage DOH!!!!!!!!
Looks to be if parcel monkey is the best.
Could someone check out the prices, to make sure i am seeing it right.
LENGTH 80CM X WIDTH 40CM X 80CM HEIGHT
Weight is 25kg! (corsair 800d)
This. Parcel2go has always delivered the cheapest price unless I had some oversized item to send in which case I use the pallet netwrok to send it for £58:(
Parcel2go is quoting £20 +vat for a 3 day delivery.
It's not the weight that's the problem it's the size of the thing, it's huuuge.
Can't you get it any smaller?
Well the box is 80cm High x 40cm wide x 80cm long. 25KG
I am getting quotes via parcel monkey for like £11 ish plus VAT. More than happy with that!
Would just like someone to check it :) As its over HALF of everyone else :eek:
Oh an 800D
*heads off to google*
If I'm looking the correct item its specs are 609mm x 229mm x 609mm
If you can squeeze this in a 75 x 30 x 75 box, maybe by loosing some packaging it's coming in at £8.99 +vat.
Or even £5.95 +vat for 2 days.
Status
