Need help with Gentoo install
20 Sep 2003
Scotland
Im installing gentoo for the first time and i have hit my first probliem
I have just compiled my kernal and the manual says to copy my kernal to /boot but i need to know what my kernal version is. How do i do that ?
you dont really need to know the kernel version, just know the name you give the kernel in the /boot folder. It is usually best to name the kernel so that if you have several in there you know which is which. Its only a reference for grub though.
also "uname -a" won't work, because that will give the name of the kernel that he is installing from, not the kernel he has just compiled.
Typing
Code:
make install
works here (copies the kernel as /boot/vmlinuz-kernelversion with a symlink @ /boot/vmlinuz). It will complain that no bootloader has been installed, but it will copy the kernel anyway.
i have another small problem, since posting this question i have restarted my linux box and it wouldnt boot so i booted of the live cd again. I am now at the install screen with and it says
livecd root #
where as before it said
livecd linux #
now it wont recognise my commands, how can i get back tot the stage i was at ?
livecd root #
livecd linux #
Repeat the chroot step and cd to /usr/src/linux.
Mount your partitions again, eg:
Code:
mount /dev/hda3 /mnt/gentoo
mount /dev/hda1 /mnt/gentoo/boot
mount /dev/hda4 /mnt/gentoo/home
mount -t proc none /mnt/gentoo/proc
and, as suggested, repeat the chroot step:
Code:
chroot /mnt/gentoo /bin/bash
env-update
source /etc/profile
right if i do
make install
i get this error
make: *** No rule to make target `install`. Stop
DezUk said:
right if i do
make install
i get this error
Probably best to follow the instructions for now:
Make sure /boot is mounted (probably already is)
Code:
mount /boot
Make sure you are in the right place:
Code:
 cd /usr/src/linux
Copy the newly compiled kernel to your /boot partition, example
Code:
cp arch/x86_64/boot/bzImage /boot/kernel-2.6
That's for an amd64 machine (x86_64) so it may be different depending on your cpu. You can name it kernel-2.6 or gentoo-kernel-2.6-squiggle if you like. Just remember what you've named it when it comes to writing your grub.conf or lilo.conf (i.e. be consistent) :)
