My little Toshiba Satellite has been with me for 3 and a half years now, and I think the little fella is on his deathbed. The laptop locks up quite often and regularly reaches over 100C in both cores, and becomes very physically hot. I was wondering whether it would be possible to get it refurbed somewhere? I'm clueless on laptops, what would it involve them doing to it and how much would it cost?
CPU - Intel Celeron T1600 1.6ghz duo core
GPU - 124MB Intel Express Family Chipset
RAM - 2GB DDR2
OS - Vista x32
Thanks!
RAM - 2GB DDR2
OS - Vista x32
Thanks!
It's worth a go first off if you want to avoid a strip. Blow the **** through the vent on the side and hoover through the air vent on the bottom.
