need help with mounting HP 24xw monitor vertically
19 Jan 2021
apologies if I'm not using the correct forum etiquette, it's my first time one here.
**i have seen some vesa adapters for this monitor, however the "slot in" style fitting isn't particularly tight so I wouldn't trust it for vertically mounting**
i have a 27 inch gaming monitor, however i would like to mount my 24xw vertically for programming, has anyone found a good solution for this, or know of a decent product I could use, most of the non vesa monitor holders seem to only work for horizontal applications.
Thanks in advance!
Depends on budget I guess; I use a humanscale m/flex m2 which has dual monitor capacity - and allows me to move the monitors from horizontal to vertical pretty simply.
Downside is cost - plus side is... its v good. You can probably find them on well known online websites for much less than RRP. ;)
