- 4 Oct 2008
- London
Everything looks good man, and yea ati all the way for now. Good luck
I'm sure I read the i7 is still better then amd 6core?
ahh this is just such a pain deciding
the only thing is that ive had 4 gb of RAM all this time so if im gonna upgrade then I wanted to upgrade to 6 gigs (thats my mindset!)
wouldnt the extra 2 gigs be used when transcoding 1080p raw files?
cool, thanks for clearing that up.. will the 6cores work in the amd2 plus boards with ddr2 ram? and nice to see amd stepping up! but looks like I wont be updating rig soon, but friend has the old amd processor and if it will work with the ddr2 n amd+ im sure he will love it
You would need the motherboard model number, then check the manufacturer website for a bios update/CPU support list.
ah well thanks for the help guess im going AMD
now gotta wait for june 7th to come! hopefully by then things are lower in price
Ati don't have 3D.
