specs:
abit AN52
sapphire ati 2600 pro
amd 5200
corsair 2gb 6400c5
huntkey 500W
ok got the bits today and started to install them into my case, everything went in fine, installed everything apart from the optical drive and the hard drive
plugged psu in and then hooked up my screen and when i turned it on fans span up and lights on the board came on, but nothing came on the screen i checked the CPUand GPU card and seem to be ok
any help appreciated,
thanks
*EDIT*
just noticed that the GPU cooler fan is not spinning anymore it used to.. but it tryes to spin up when i turn the PSU off at the switch
abit AN52
amd 5200
corsair 2gb 6400c5
huntkey 500W
thanks
*EDIT*
