Need Help With My Gaming PC Build
15 Nov 2015
What is your intended use for this build? The more details the better.
Gaming, Editing Videos, Livestreaming,
If gaming, what kind of performance are you looking for? (Screen resolution, FPS, game settings)
I want it to handle the latest games on ultra max settings or at least high settings and above 60fps in any situation, even while capturing gameplay, will at first be using 1920x1080p res screeen 120hz 1ms reponse time 2 monitors 1 for gaming other for livestream chat browsing internet etc.
What is your budget (ballpark is okay)?
£5000-£6500 or just above For PC and £1000-1500 for the other parts listed but if the other parts dont cost that much then i can stretch my pc price up more.
In what country are you purchasing your parts?
United Kingdom - will be using various sites to purchase them
*Logitech HD Pro Webcam C920 £85
*DXRacer King Series Chair - £270 - could go for gtomega if its still good just need it to be comfortable for long sessions of gameplay.
*Blue Yeti Microphone - £90 but with pop filter and mic arm total £119 Green *Screen + Lighting = ?? - don't know whats best to get for this don't need it expensive just good enough for what i need it for.
*Desk = ?? - need desk that can hold 3 monitors and a desktop pc (for now only using 2 monitors but want room for 3)
Computer Spec/Pricing:
Obsidian 900d Full Tower Case - £300
BitFenix Alchemy 2.0 Magnetic Connect 30 LED-Strip 60cm - Red - £22 rough estimate - will this be enough led strip for top an bottom of the 900d?
Corsair AFSeries 140 1200RPM LED Fan Quiet Edition Single Pack x1 £11 - Rear Exhaust Corsair AFSeries 120 1500RPM LED Fan Quiet Edition Single Pack x3 £27 - Front Panel
Corsair SPSeries 120 1650RPM LED Fan High Pressure Twin Pack x6 £102 - Top and Bottom Radiator Fans
Invidually Sleeved Red Cables £?? need list of all cables in a pc that can be invidually sleeved so i can look it up.
i7-5930K 3.50GHz Processor - £470
Red Aluminum TITAN X/980Ti Water Block Retention Backplate x2 £61
EVGA GeForce GTX 980 Ti 06G-P4-5998-KR 6GB K|NGP|N w/ACX 2.0+, Whisper Silent w/ Multi-Color LED Cooler, Customized Overclocking Graphics Card x2 £1500
Asus Rampage V Extreme Motherboard - £370
GSkill Ripjaw V 32gb DDR4 Memory 3200mhz (8GBx4) - £243
Red Coolant £?? what brand is the best and type of red that actually looks red in system.
EK-RES x3 250 £39
Corsair AX1500i Digital ATX 80 Plus Titanium Modular Power Supply £350 or SuperFlower Leadex Platinum Edition 2000w Fully Modular 80 Plus Power Supply - £330 - if these are to high in watts then would a 1200 watt be plenty?
Samsung 850 Pro SSD £180
Western Digital 4TB HardDrive £176
LG BH16NS40 16x SATA Internal BDRW - £55
XBox One Controller (PC-Version) £43
Razer Blackwidow Chroma Keyboard - £140
Astro a40 Gen2 Headset £200
Windows 10 64Bit - £80
Bulguard Premium Anti Virus Software £70 origional price 50% discount at the moment for £35
Adobe Suite - E.G Photoshop, AfterEffects CC etc - £36 a month for annual plan for all apps.
OBS - OpenBroadcasterSoftware - Free
Note: Need some experienced people to look over my spec and other parts and see what you can do to get me an awsome gaming pc build going for a red and black themed look and if theres things in the other parts you can reduce in price thats not needed and can be changed at a later date then please find me alternatives to them please so i can get best parts out of my pc as possible.
I'm missing watercooling parts from my list ive got the res on there but i dont know what parts i need to look for so
*Radiators i need going for 1 at the top, 2 at the bottom at the sides of the case i mean and what make is best for this im probs thinking 4 fans on a rad at top - 4 on the bottom rads aswell
*PrimoChill Clear Tubing - i need to know what size and how much of it will i need.
*Bitfenix Black or red? Fittings - how many and what types of fittings do i need
lastly if you see better upgrades in my spec that ive listed please list them and reason why whilst staying in the same budget region
thanks
/Eremus28
Please take this us nothing but friendly advice...
The reason you aren't getting much of a response is probably due to this post should really be in the general hardware section. You've pretty much just asked for buying advice mainly as opposed to it being a true Project Log.
Your budget is certainly impressive... I work out 4822 not including your subscriptions or missing parts.
Wouldnt you be better of with a prebuit system like this.
Or you could even ring them up and say how you would like it.
Case:Phanteks Enthoo Luxe Full Tower Case - Black[/SIZE] [*] Memory:Kingston Fury Black 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/32 [*] Primary Solid State Drive:Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) [*] Secondary Solid State/Hard Drive:Seagate 3TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST3000DM001) [*] Tertiary Solid State/Hard Drive:Unwanted [*] Graphics:2x Watercooled Nvidia GeForce GTX 980Ti 6GB Graphics Cards Configured in SLI [*] Watercooling Fluid Colour:2 Litre Fluid Bundles - Black Pastel [*] Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) [*] Security Software:ESET Smart Security - Trial Key [*] Warranty:OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour) [/LIST] [/LIST]
Total: £3,333.98 (includes shipping: £14.10)​
[url=https://www.overclockers.co.uk/infin8-swarm-intel-core-i7-5820k-4.4ghz-overclocked-watercooled-extreme-gaming-pc-fs-453-oe.html]
"]My basket at Overclockers UK:
  • 1 x Infin8 Swarm - Intel Core i7 5820K @ 4.4GHz Overclocked Watercooled Extreme Gaming PC = £3,319.88
    • Case:Phanteks Enthoo Luxe Full Tower Case - Black
    • Memory:Kingston Fury Black 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/32
    • Primary Solid State Drive:Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
    • Secondary Solid State/Hard Drive:Seagate 3TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST3000DM001)
    • Tertiary Solid State/Hard Drive:Unwanted
    • Graphics:2x Watercooled Nvidia GeForce GTX 980Ti 6GB Graphics Cards Configured in SLI
    • Watercooling Fluid Colour:2 Litre Fluid Bundles - Black Pastel
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • Security Software:ESET Smart Security - Trial Key
    • Warranty:OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
[/URL]
£6000 and thats all you get, wow!
Lets just get this out of the way, are you on anything, £6000 PC and only a 1080p screen...??????
Right, anyways, you will want to go either 4k or 1440p for this to even be worth anything to you, than a nice big number in the top right/left of your screen and some good benchies.
Look at an Acer Predator X34 G-Sync for gaming (ultrawide is amazing) and then a 27 inch IPS monitor for your chats etc.
For £7500 (including chair etc)
Blue Yeti & arm - 119
GTOmega chair - 229
Logitech G920 - 89
Look at Ikea for a desk you like and is big.
For pc:
Total: £3,367.99
(includes shipping: £23.10)
From there, add in all the watercooling bits and bobs that you want, but thats your money spent better, if you really wanted to spend more, get another 980ti and a bigger PSU and watercool the F out of it. With that motherboard, you can watercool it too if you buy the block.
Good luck :)
How big are you on twitch by the way? Seems excessive to start streaming and buy a PC just to go for a fantasy you will probably get bored of, like many others.
