Need Help With My Gaming PC Build
15 Nov 2015
Hello guys need your help :)
What is your intended use for this build? The more details the better.
Gaming, Editing Videos, Livestreaming,
If gaming, what kind of performance are you looking for? (Screen resolution, FPS, game settings)
I want it to handle the latest games on ultra max settings or at least high settings and above 60fps in any situation, even while capturing gameplay, will at first be using 1920x1080p res screeen 120hz 1ms reponse time 2 monitors 1 for gaming other for livestream chat browsing internet etc. note: do you know any good 1440p monitors that are 1ms and either 120 or 144hz reponse time that doesnt cost the earth I just want it reasonably priced.
What is your budget (ballpark is okay)?
£5000-£6500 or just above For PC and £1000-1500 for the other parts listed but if the other parts dont cost that much then i can stretch my pc price up more.
In what country are you purchasing your parts?
United Kingdom - will be using various sites to purchase them
*Logitech HD Pro Webcam C920 £85
*DXRacer King Series Chair - £270 - could go for gtomega if its still good just need it to be comfortable for long sessions of gameplay.
*Blue Yeti Microphone - £90 but with pop filter and mic arm total £119 Green
*Screen + Lighting = ?? - don't know whats best to get for this don't need it expensive just good enough for what i need it for.
*Desk = ?? - may use ikea or if theres another place you know of where i can get it for my country then please let me know so need a desk that can hold 3 monitors and a desktop pc (for now only using 2 monitors but want room for 3) - you see where I'm comming from i spent all that money on a awsome rig i want it showing not hidden under my desk if you get what i mean but if its not possible then ill want something under my desk to hold my pc off the ground cause its bad to have it on the floor.
Computer Spec/Pricing:
*Obsidian 900d Full Tower Case - £300
*BitFenix Alchemy 2.0 Magnetic Connect 30 LED-Strip 60cm - Red - £22 rough estimate - will this be enough led strip for top an bottom of the 900d?
*Corsair AFSeries 140 1200RPM LED Fan Quiet Edition Single Pack x1 £11 - Rear Exhaust Corsair AFSeries 120 1500RPM LED Fan Quiet Edition Single Pack x3 £27 - Front Panel
*Corsair SPSeries 120 1650RPM LED Fan High Pressure Twin Pack x6 £102 - Top and Bottom Radiator Fans
*Invidually Sleeved Red Cables £?? need list of all cables in a pc that can be invidually sleeved so i can look it up.
*i7-5930K 3.50GHz Processor - £470
*Red Aluminum TITAN X/980Ti Water Block Retention Backplate x2 £61
*EVGA GeForce GTX 980 Ti 06G-P4-5998-KR 6GB K|NGP|N w/ACX 2.0+, Whisper Silent w/ Multi-Color LED Cooler, Customized Overclocking Graphics Card x2 £1500
*Asus Rampage V Extreme Motherboard - £370
*GSkill Ripjaw V 32gb DDR4 Memory 3200mhz (8GBx4) - £243
*Red Coolant £?? what brand is the best and type of red that actually looks red in system.
*EK-RES x3 250 £39
*Corsair AX1500i Digital ATX 80 Plus Titanium Modular Power Supply £350 or SuperFlower Leadex Platinum Edition 2000w Fully Modular 80 Plus Power Supply - £330 - if these are to high in *watts then would a 1200 watt be plenty?
*Samsung 850 Pro SSD £180
*Western Digital 4TB HardDrive £176
*LG BH16NS40 16x SATA Internal BDRW - £55
*XBox One Controller (PC-Version) £43
*Razer Blackwidow Chroma Keyboard - £140
*Astro a40 Gen2 Headset £200
*Windows 10 64Bit - £80
*Bulguard Premium Anti Virus Software £70 origional price 50% discount at the moment for £35
*Adobe Suite - E.G Photoshop, AfterEffects CC etc - £36 a month for annual plan for all apps.
*OBS - OpenBroadcasterSoftware - Free
Note: Take a look over my spec and other parts and see what you can do to get me an awsome gaming pc build going for a red and black themed look and if theres things in the other parts you can reduce in price thats not needed and can be changed at a later date then please find me alternatives to them please so i can get best parts out of my pc as possible.
I'm missing watercooling parts from my list ive got the resovoir on there but i dont know what parts i need to look for so:
*Radiators i need 1 at the top: thinking 480 rad?, 2 at the bottom: so 1 480 rad on window side an 360 on other side? or can it fit a 480 in a 900d case? at the sides of the case i mean and what make is best for this im probs thinking 4 fans on a rad at top - 4 on the bottom rads aswell
*PrimoChill Clear Tubing - i need to know what size and how much of it will I need - not sure on if i should go acrylic or just regular flex tubing heard people say if your not in a rush to upgrade then go acrylic but yeah.
*Bitfenix Black or red? Fittings - how many and what types of fittings do i need - don't want to go overboard with fittings cause can get to an expensive price with them so just the amount i need will be great.
lastly if theres a potential upgrade on any of the parts ive listed but stays in the same price bracket then please could you add them so i can look it up and then add it to my list please thanks.
