Need help with my monitor
16 Nov 2011
Hi I just water cooled my pc today but when I turned it on my monitor would not work :(
Basically when I turn it on it show the bios but not in the right resolution then when windows boots up there is noting just a black screen but if I connect my tv with the hdmi lend it works fine
Anybody any ideas what is wrong with it?
Is the GPU watercooled? If so what block and did you use a backing plate? What GPU is it?
I have updated the driver to a new beta driver with no joy although I haven't tried to do a clean install.
Yes the gpu is watercooled I used the evga waterblock and back plate for my 780 classified
Just wondering if there is a possible short on the backplate? You could try it without the back plate or remove and reattach it. Did you leave the inside plastic cover on?
On the instructions it say remove the plastic cover you would think that they would say do not remove the back plastic cover . Not very clear instructions.
Does display port image quality match dvi? I'm gaming at 1920x1200. Really couldn't be annoyed draining my loop to take of the backplate
