- 6 Nov 2009
Hey, I've started making animated videos using Adobe Illustrator and After Effects, but my PC is really old and struggles running these programs. Could anyone help suggest a new PC for me?
It would mainly be used for using the above mentioned software, but also be able to play some games too. My main priorities would for it to be quick and also quiet, as I record voiceovers, so super loud fans can be a problem.
Budget around £1000, but could stretch further it if would make a worthwhile difference. A monitor isn't required at the moment but will probably upgrade to a superwide at some point in the future.
Thanks!
Thanks!
