need help with overclock please
26 Jul 2011
West Yorkshire
hi i keep getting BSOD after playing starcraft 2 for an hour or so, it has done it in codmw2 aswell
asus crosshair4 formula, phenom ii X4 955, corsair dominator 1600MHz(2X4GB)
15.5X257
CPU 3983MHz-1.471V
RAM 1713MHz-1.55V
CPU/NB-2570MHz
NB Volts-1.275
SB Volts-1.31
HT link speed-2313MHz
HT Volts-1.275
any help muchly appreciated
hi thanks for fast reply :)
i have tried a lot of settings and you're right my cpu doesn't like 4GHz or more (which is annoying as i see a lot of 4.2 on youtube but oh well)
and my RAM doesn't like more than 1760MHz, maybe its till not low enough? the ram speed only moves in around 400MHz increments, therefor i may havto resort to lowering the FSB(?) which will lower CPU too
i use coretemp and it says my custom watercooling loop keeps it under 52*C @ 100% load, after it has been warmed by gaming or stress testing it idles to about 34*C
nice to know its not just me
i am hoping to get something more out of my ram as well as cpu but if i havto resort to using just the multi i will, thanks
sorry i wrote that wrong, i have 2X2GB so removing 4GB would be baaaaad :P i have upped the CPU/NB one step as you suggested though so i will starcraft 2 test it soon
your 955 is at 4.2, nearly 4.3! :( lucky you though, congrats!
what is CnQ? a BIOS option i guess?
i am 99% sure that was one of the many settings i tried and it wouldn't have it
either that or i decided to be very tight and get the max out of my ram
oh yeah i heard that.
well not only did i complete 5 hrs and 10mins of prime 95 blend test successfully but i haven't had a blue screen of death since upping the CPU/NB frequency 1 step so thanks very much for your help :)
ok well its been 5 days without a BSOD but just had one now while watching a replay in game :( any suggestions regarding OC? voltages look ok?
