Need help with parts :)
11 Jul 2003
Telford//west mids
Im getting back into watercooling with luck it will be with the corsair 900D case :D and for now ill be cooling just the cpu (2011 3820 @4.5ghz) will add more when I can.
So ill need
3 x 120 rad
Fans for rad I like the look of the corsair ones not sure what model to buy.
D5 pump with bay rez or D5 and standalone rez.?
Cpu waterblock?
Hose size?
And some nice compression Fittings
Thanks.
900D is quite a big case so I would recommend a more powerful pump like Koolance PMP-500 in case you will add something more to the rig...
Personally fancy Koolance 370 CPU blocks :D
Whent for the Koolance RP-452X2 Dual 5.25" Reservoir Single / Dual Loop for 1 or 2 Laing D5 Pumps : RP-452X2 Rev2.0 and a Koolance PMP-450 High Flow Pump : PMP-450 can add another pump later on.
Fans ive got 6 x Corsair SP120 Quiet Series High Pressure Low Noise for the rad.
Looking at the raystorm and koolance cpu block will have to do a bit of reading to see what one is better.
Hose size will be going 1/2.
