Hello, due to space constraints I will be making a mini PC build but I don't want to compromise on performance or cooling which I know will be a challenge.
My aim is to make it as silent as possible. I've been looking at some cases and it can't really be any bigger than a silverstone RVZ01. That case really caught my eye since it doesn't have many compromises.
Will a 5930k be able to stay cool with a low profile cooler in there? Any suggestions for coolers that will fit?
I will need a blue ray and dvd writer and reader and I saw that it only takes slimline ones. Also the power supplies are the sff versions so which are the most reliable and quiet ones?
My budget is whatever I need to make a decent pc which is silent and cool which will be small enough. I have a monitor and mouse and keyboard so that is fine. I just need the system itself.
If anybody has a sff PC please post it here so I can see how it is set out. Thank you all in advance.
