Need help with Raid!!!
5 Apr 2006
Ok later on today I am going to get my new HDD a maxtor 250GB SATA in which it gives me loads of space since I will then have 4 HDD's installed and then I can set up raid, I heard how it is so good and makes your computer run faster but I don't even know anything about it.
Come someone explain in simple terms excually what it is used for and why I should use it?
What Raid do you intend to use?
Raid - 0 Striped for performance :
I have Raid - 0 and windows installs and loads slightly faster than standard HD setup. Game level loading also is noticibly quicker. Reliability is said to be questionable but I have never had a drive fail on me. If one HD fails then all your data is gone. Most commonly used raid setup.
Raid - 1 Backup : Never used this myself as this will half the disks total storage space as the data is written to one drive and then duplicated to another. The benifit is that if one drive fails you still have all your data intact backed up on the other drive. If Data backup is important to you then I suggest you use this.
Raid 0+1 : You will need more than 2 drives for this and it is basicly a combination of the above.
Unless you have a dedicated raid controller (most don't) you will be using an onboard controller such as NVRaid or Silicon Raid (both software), NV raid is said to be better both in terms of reliability and speed, a dedicated hardware raid controller will give much improved results but they are very expensive. There are other versions of Raid (5 and other combinations) but the above versions are the most commonly used.
Hope this helps.
Here are the HDD's I have or will have in 1 hour
250gb SATA (Not sure of model yet) - 7200RPM
120gb SATA Seagate Barracuda - 7200rpm
120gb IDE Seagate Barracuda - 7200RPM
40gb IDE Western Digital Protégé - 5400RPM
Now I wouldn't even know what to do or even how to use Raid.
So far I have:
120gb SATA Seagate Barracuda - 7200rpm as my master with my OS on there
120gb IDE Seagate Barracuda - 7200RPM - Backup drive
40gb IDE Western Digital Protégé - 5400RPM - Backup Drive
change the 120gb IDE Seagate Barracuda for a sata one to match your other seagate drive, then raid the 2 seagate sata drives Using nvida chipset from your bios.
you want all sata drives to be honest and same size
I have just brought a 250gb from my m8 so I can't afford to buy another 120gb SATA drive unless someone wants to swap my IDE for a SATA, not gonna happen though
Not much scope for raiding there mate, not without wasting a lot of dis k space (eg RAIDing the 2 SATA drives)
I'm pretty sure JBOD (just a bunch of disks) RAID will allow you mix drive sizes. Unfortunately, your motrherboard probably doiesn't support it, so you're looking at an expensive upgrade card.
Sell the 40GB and the 120Gb PATA drives and buy another 250Gb SATA drive.
First decide what RAID you want, RAID-0 for speed?
JBOD isn't faster than single drives as all it does is span a partition over multiple drives.
What mobo have you got?
