Hey there,
Right my tv upstairs has a built in Freesat, has a satellite connection on the back.
Downstairs we have SKY HD.
And I don't know much about satellite dishes etc, but I know that if you have a quad LMB you can connect more cables into it etc to go to more devices am I right?
And iv just been looking at my sky dishes LMB from down below, I can see 4 holes where cables go in, heres some pictures:
So, would it be a simple case of buy some satellite wire, stick it in one of them holes then plug the other end into the back of the tv?
Also, I haven't been up to see if theres anything inside them 2 holes without wires in cant see from below, but if it would be a case of simply get some wire and stick it in then id check to see if it has any open connections first
Thanks
Thanks
