Hi everyone.
I use steam and i've got quite a lot of games on it. I want to do a clean install of my system but i dont want to have to redownload all my games again. Is there a way i can avoid this? Thanks
how can i split my steam folder over 2 discs
how do i backup my game saves?
Stream installed on a seperate partition is the way to go definitely. As dirtydog said you won't even need to reinstall it. When I first installed Steam on the same partition as my OS and had to reinstall Windows, copying steamapps back didn't work for some reason. TF2 wouldn't load, it gave me some errors. I had to reinstall and download the games again.
i hate waiting to install games.Just copy and paste the entire Valve folder.How do i install steam on a seperate partition?
Not at all. You can install stuff anywhere you want.I thought things can only be installed on the same partition as the OS
You can't, your Steam games can only be installed on the Disc the Steam client has been installed
How do i install steam on a seperate partition? I thought things can only be installed on the same partition as the OS
