Need help with upgrade
23 Nov 2005
London
Hi,
As a student finding the money for upgrades and whatnot is quite hard and when i do get some money it isnt a lot so im in a bit of a predicament. I want to spend max £150 and ill need a mobo, cpu and ram.
This is where the problem is for that money i can get an AMD system based around a 5200+ but the problem is i dont know which motherboard to buy.
On the other hand i would like to buy a c2d system as i know they are better but in that price range it looks as if it is going to be hard to get a decent cpu and mobo as decent c2d mobos seem a lot a more expensive than amd ones.
if you only need MB cpu and ram
Your basket
Product Name Qty Price Line Total
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard £54.99
(£64.61) £54.99
(£64.61)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £29.99
(£35.24) £29.99
(£35.24)
Intel Core 2 Duo E2140 "LGA775 Conroe" 1.60GHz (800FSB) - Retail £35.99
(£42.29) £35.99
(£42.29)
Sub Total : £120.97
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
VAT is being charged at 17.5% VAT : £22.61
Total : £151.83
a tiny bit over, get the IP35MB if you can afford the extra,will be a better OCer and or E2180 as it is easier to OC due to higher multipliers
what speeds do you think ill get with an e2140?
and ive got thermalrite si-120 cooler is it compatible witht that mobo?
