Need Help.
26 Nov 2003
Chelmsford
Hey there,
I have a wireless router which is connected to my cable modem. My main PC is also connected to the router. The internet works on both my laptop(wireless) and main pc. But no matter how hard I try I can't get network sharing working. Ive tried creating a workgroup but I get:
"Workgroup is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
The list of servers for this workgroup is not currently available"
Any ideas?
Firewalls?
Can you ping one machine from the other?
Output from start, run, cmd, ipconfig /all might not go amiss either.
Standard windows firewall, router has a built in one too. I can also ping the laptop via its lan IP.
Code:
        Host Name . . . . . . . . . . . . : KAINE
        Primary Dns Suffix  . . . . . . . :
        Node Type . . . . . . . . . . . . : Unknown
        IP Routing Enabled. . . . . . . . : No
        WINS Proxy Enabled. . . . . . . . : No
        Ethernet adapter Local Area Connection:
        Connection-specific DNS Suffix  . :
        Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
        Physical Address. . . . . . . . . : 00-01-29-F9-83-BB
        Dhcp Enabled. . . . . . . . . . . : Yes
        Autoconfiguration Enabled . . . . : Yes
        IP Address. . . . . . . . . . . . : 192.168.2.102
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . : 192.168.2.1
        DHCP Server . . . . . . . . . . . : 192.168.2.1
        DNS Servers . . . . . . . . . . . : 192.168.2.1
        Lease Obtained. . . . . . . . . . : 28 February 2006 19:59:23
        Lease Expires . . . . . . . . . . : 05 March 2006 17:52:25
Also, I believe I may have turned some services off awhile ago (Blackviper). Which would need to be on?
