- 10 May 2006
Hi all,
I need some help, my friend is building a pc. He needs to choose: AMD64 3800+ or the Pentium D 805, he also wants to overclock. If he gets a AMD he can get the DFI Ultra D(which is really good, i heard) or if he gets the Pentium D, which should he get then?
Also what ram should he get? (DDR400) Preferable G.Skill. Since I dont know much about the speed FSB/RAm should be the same?
The pentium D is also 25€ cheaper then the AMD. So if the chooses the PD, he can spend it on a good HS? He's not going to wait for conroe.
