Ok, PC arrived yesterday from OCUK for my GF and it wont work.
Problem: Basically, the PC shuts itself down after being turned on for 5 minutes. The only thing that has been done to the pc since it arrived, is that it has been connected to the internet, and world of warcraft has been installed. All the relevant updates to windows have also been done.
The pc did shut itself down a number of times whilst installing world of warcraft, but it was able to stay on for longer durations. Since then it powers down much sooner, and can't handle loading any applications. I even tried going through re installing windows with her over the phone, but the pc shut itself down before we could get into the re installation.
The pc will shut itself down, then whenever she tries to turn it back on, it often powers up, but no signal is sent from the pc to the monitor.
It has got tot he point now, where the pc can be powered up with zero being done to it, and it will still turn off. I've double checdked with her that the power options are correct.
What should we do?
What should we do?
check with ocuk tho before popping open your side panel wouldnt want you to void the warranty
