First of all sorry if this is in the wrong place?
Well this all started about 6 months agow when i got my new router (Finilay found out what is probery causing the problem) and its only happing with crysis multiplayer because MW2 and LFD2 dont seem to be affected. The problem is when im playing power struggle (doesnt seem to happen with most of the TIA servers) when connecting to the server (noobhunters or ultragamming) it just hangs for ages with the loading bar full and the music is still going and if i leave it for 10-20 min it goes back to the main server list and says ''server dissconnected'' or ''connection time out'' but somtimes i get in and everything is fine for about 5 min then after i die the spawncounter stays up and says 0 secs till spawn and i spawn with nothing infront of me and i dont get wep or fists and can run about and then randomly be killed with me seeing nothing moving about around me or everyone will start running the same way constant and not move but i can still run about ect...
I need this to be fixed ive trying new graphics card cleaning out computer reapplying thermal paste incase it was overheating but my temps were fine. Tryed closing down all background tasks, deleting and disabling mcAfee anti virus
so i think its my router its the problem because it seems to be network related (like everything is really behind in game) and was wondering if anyone could help me get the internet to my computer without using the router or if i have to open up some ports to stop it (like MW2 making nat type change to open from strict).
my spec are... if it helps?
Dell XPS 420
windowns vista 32 bit home pre
Q6600
5770 Vapour-X
3 gigs of dell 667Mhz ram
hp w2207h 22" screen
and my router is...
Linksys wireless G compact router (but my pc's got an eithernet comming from the router into my pc)
any help would be great thanks
so i think its my router its the problem because it seems to be network related (like everything is really behind in game) and was wondering if anyone could help me get the internet to my computer without using the router or if i have to open up some ports to stop it (like MW2 making nat type change to open from strict). my spec are... if it helps?
Dell XPS 420
Q6600
5770 Vapour-X
and my router is...
its just starting happing since the new router which my dad wanted for his livingroom computer
